Weld 1
StrP88
189
I appreciate your input
I have the option to locate the weld parallel to the load "P" or perpendicular to the weld, any of the choices is better or recommended from the other?
Thank you
I'm guessing that this thread is related to this one: Link. If so, nominal 2" fillet welds on the top flange of the low beam ought to be sufficient.
Thank you all equally to not offend anybody.
I appreciate all helps truly.
Kootk, your explanation was very clear and no needed for a sketch.
Teguci, thank you for the link, it was good information. And you I appreciate you for your discussions and that caused I learn a lot.
You guys are great.
Thank you all
I'd say that something like this is typical. The stiffeners can be omitted or made partial height if one invests the time to justify those decisions.
