Wave, save A as new revision of existing B 2
lbd7700
Computer
Sep 9, 2011
24
Hi
In NX9/TC10, is there a way to save one revision of file A, as a new revision of an existing file B?
Save as, new item, gives errors when file b already exists.
File, new, also fails if file b already exists.
Clone assembly also fails if file b already exists.
So far the only options are changing .prts in the UG dataset in tc, or using, file import part.
But this options can't be used when waves are used, for the cases where you want the waves to point to the new item and not the original item.
The only process I know that updates wave links is the clone assembly command, but it only work when creating revision of same item.
Is there a way to use clone assembly to create a new revision of a different item?
I wrote a journal to that for my company platform.
Its took me a hard work to it to fit the platform.
by trying and failed.
I don't know if it will work in your platform.
I'll have about two week to reached my code
clean it from company marks and post it
Hi a984928
Thanks, can you please explain how this journal accomplishes the task?
Which steps does it perform?
The journal export partArevx renamed to partBrevy to
A windows folder and then import partBrevy to TC
Interesting. Having as a journal is awesome, I will try and do it manually to see the result.
I'll try to post it as soon as I can
Yes you can try it manually
I used the options 'auto translate' and 'use existing'
a984928, I did a small test and it worked wonderfully.
Wave links were relinked correctly and the drawing didn't loose dimensions associativity.
I will do more testing but this looks very promising so far.
Hi
here is my journal
please tell me if its works in your platform
Code:
'Modified on 10 mar 2016
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Module nx_manaqger_save_xpartxrev_as_ypartyrev_xyparts_exist_in_db
 Sub Main()
   Dim s As Session = Session.GetSession()
   Dim lw As ListingWindow = s.ListingWindow
   Dim ufs As UFSession = UFSession.GetUFSession
   Dim source_master As String
   Dim source_rev As String
   Dim target_master As String
   Dim target_rev As String
   Dim windir As String
   Dim windrv As String
   Dim pdm_master As String
   Dim pdm_specs(20) As String
   Dim win_master As String
   Dim win_specs(20) As String
   Dim dsn As String 'dataset name
   'create new form object
   Dim myForm As New UserInputForm
   'Dim myForm As UserInputForm = New UserInputForm(var1)
   myForm.DialogSetDefData( "part_B393-01", "-", "part_A193-01", "C", "D")
   If myForm.ShowDialog() <> DialogResult.OK Then Exit Sub
   If Not myForm.DialogGetUserData( source_master, source_rev, _
                                target_master, target_rev, windrv) Then Exit Sub
   lw.Open()
   ufs.Ui.ExitListingWindow()    ' Clear and  close the window
   windir = windrv & ":\" & target_master & target_rev & "\"
   pdm_master = "@DB/" & source_master & "/" & source_rev
   win_master = windir & target_master & "_" & target_rev & ".prt"
   lw.WriteLine("=============================================")
   lw.WriteLine("pdm_master = " & pdm_master)
   lw.WriteLine("")
   lw.WriteLine("windir = " & windir)
   lw.WriteLine("")
   lw.WriteLine("win_master = " & win_master)
'================ Export to native =================
   Try
    ' Determine whether the directory exists.
    If Directory.Exists(windir) Then
      lw.WriteLine(windir & "  path exists already.")
     Else
      ' Try to create the directory.
       Dim di As DirectoryInfo = Directory.CreateDirectory(windir)
       lw.WriteLine(windir & " Directory was created successfully at {0}." _
                                             & Directory.GetCreationTime(windir))
     End If
     ' Delete the directory.
     'di.Delete()
     'lw.WriteLine("The directory was deleted successfully.")
   Catch e As Exception
     lw.WriteLine("The process failed: {0}." & e.ToString())
   End Try
  Dim load_status As UFPart.LoadStatus = Nothing
  ufs.Clone.Terminate()
  ufs.Clone.Initialise(UFClone.OperationClass.ExportOperation)
  ufs.Clone.SetFamilyTreatment(UFClone.FamilyTreatment.TreatAsLost)
  ufs.Clone.setDefNaming(UFClone.NamingTechnique.Autotranslate)
  ufs.Clone.SetDefItemType ("")
  ufs.Clone.SetDefDirectory(windir)
  'ufs.Clone.EnsureDefDirectory (windir)
  ufs.Clone.SetAssocFileRootDir (windir)
  ufs.Clone.SetDefAction(UFClone.Action.Overwrite)
  ufs.Clone.SetLogfile(windir + "export_clone.txt")
  ufs.Clone.SetDefAssocFileCopy (True)
  ufs.Clone.AddAssembly(pdm_master, load_status)
  Dim prt_cnt As Integer = 1
  Dim spc_cnt As Integer = -1
  Dim prt_name As String
  ufs.Clone.StartIteration()
  Do
    ufs.Clone.Iterate(prt_name)
    If(prt_name = Nothing) Then Continue Do
   lw.WriteLine("Export Iterate Part  ==>>  " & prt_cnt.ToString() & "  prt_name  =  " & prt_name)
   Dim names() As String = prt_name.Split("/")
   If names(1).ToUpper = source_master.ToUpper Then
      If prt_name.ToUpper = pdm_master.ToUpper Then
        ufs.Clone.setNaming(prt_name, UFClone.NamingTechnique.UserName, win_master)
      End If
      If prt_name.Contains("/specification/") Then
        spc_cnt = spc_cnt + 1
        If spc_cnt < 9 Then
          dsn = target_master.RePlace("_", "") & "d" & "0" & (spc_cnt+1).ToString
        Else
          dsn = target_master.RePlace("_", "") & "d" & (spc_cnt+1).ToString
        End If
        win_specs(spc_cnt) = windir & target_master & "_" & target_rev & "_s_" & dsn & ".prt"
        pdm_specs(spc_cnt) = "@DB/" &  target_master & "/" & target_rev & "/specification/" & dsn
        ufs.Clone.setNaming(prt_name, UFClone.NamingTechnique.UserName, win_specs(spc_cnt))
      End If
   End If
    prt_cnt = prt_cnt + 1
  Loop While (prt_name <> Nothing)
  Dim naming_failures As UFClone.NamingFailures = Nothing
  ufs.Clone.setdryrun (false)
  ufs.Clone.GenerateReport()
  ufs.Clone.PerformClone (naming_failures)
'================ Import to Tce =================
  Dim cnt As Integer
  For cnt =0 To spc_cnt
    ufs.Clone.Initialise(UFClone.OperationClass.ImportOperation)
    ufs.Clone.SetDefAction(UFClone.Action.UseExisting)
    ufs.Clone.SetLogfile(windir + "import_clone" & (cnt+1).ToString & ".txt")
    ufs.Clone.AddAssembly(win_specs(cnt), load_status)
  prt_cnt = 1
  Do
    lw.WriteLine("Import Iterate Part  ==>>  " & prt_cnt.ToString() & "  prt_name  =  " & prt_name)
      If prt_name.ToUpper = win_specs(cnt).ToUpper Then
       lw.WriteLine("===========================================================")
       lw.WriteLine("  win_specs(" & cnt.ToString & ")  =  " & win_specs(cnt))
       lw.WriteLine("  pdm_specs(" & cnt.ToString & ")  =  " & pdm_specs(cnt))
       ufs.Clone.SetAction(win_specs(cnt), UFClone.Action.Overwrite, "")
      End If
    naming_failures = Nothing
  Next
   lw.Close()
   lw.Closewindow()
   msgbox("@DB/" & target_master & "/" & target_rev & " - Clone Done ")
 End Sub
 Public Function GetUnloadOption(ByVal dummy As String) As Integer
   'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
   GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
   'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
 End Function
End Module
'                   User Input Form Dialog Class
Public Class UserInputForm
   Public Sub New()
     MyBase.New()
     'This call is required by the Windows Form Designer.
     InitializeComponent()
     'Add any initialization after the InitializeComponent() call
     'TextBox1.Text = "part_B393-01"
     'NX icon in top left side
     NXOpenUI.FormUtilities.SetApplicationIcon(Me)
     NXOpenUI.FormUtilities.ReparentForm(Me)
   End Sub
   ' Returns the data selected on the form.
   ' All parameters are output parameters.
   ' This function should only be called after this form has been
   ' shown to the user and only if the user did not cancel out of
   ' the form.
   Public Function DialogGetUserData( ByRef sn As String, _
                                      ByRef sr As String, _
                                      ByRef tn As String, _
                                      ByRef tr As String, _
                                         ByRef fd As String) As Boolean
     If Me.DialogResult <> DialogResult.OK Then Return False
         'Throw New System.Exception("Illegal GetUserData calling")
     sn = frmSrcMasterValue
     sr = frmSrcMasterRevValue
     tn = frmTargetMasterValue
     tr = frmTargetMasterRevValue
     fd = frmWinDriveValue
     Return True
   End Function
   Public Function DialogSetDefData( ByRef sn As String, _
     'If Me.DialogResult <> DialogResult.OK Then Return False
     frmSrcMasterValue = sn
     frmSrcMasterRevValue = sr
     frmTargetMasterValue = tn
     frmTargetMasterRevValue = tr
     frmWinDriveValue = fd
     'Return True
   End Function
'*************** Private vars **************************
   Private frmSrcMasterValue As String
   Private frmSrcMasterRevValue As String
   Private frmTargetMasterValue As String
   Private frmTargetMasterRevValue As String
   Private frmWinDriveValue As String
   Private Sub UserInputForm_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
     TextBox1.Text = frmSrcMasterValue
     TextBox2.Text = frmSrcMasterRevValue
     TextBox4.Text = frmTargetMasterValue
     TextBox5.Text = frmTargetMasterRevValue
     TextBox7.Text = frmWinDriveValue
     'ttHint.SetToolTip(Me.btnOK, "Revise As")
     ttHint.SetToolTip(Me.btnOK, "Save the source master revision As a target master revision" _
                        & VbCr & "The source master must have a Spec drawing" _
                        & VbCr & "Both source and target masters exist in NX Manager Data Base" _
                        & VbCr & "Warning !!! no valid input checking " )
   End Sub
   Private Sub btnCancel_Click(sender As System.Object, e As System.EventArgs) Handles btnCancel.Click
     Me.Close()
   End Sub
   Private Sub btnOK_Click(sender As System.Object, e As System.EventArgs) Handles btnOK.Click
     frmSrcMasterValue = TextBox1.Text
     frmSrcMasterRevValue = TextBox2.Text.ToUpper
     frmTargetMasterValue = TextBox4.Text
     frmTargetMasterRevValue = TextBox5.Text.ToUpper
     frmWinDriveValue = TextBox7.Text.ToUpper
     Me.Close()
   End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class UserInputForm
    Inherits System.Windows.Forms.Form
    'Form overrides dispose to clean up the component list.
    <System.Diagnostics.DebuggerNonUserCode()> _
    Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        Try
            If disposing AndAlso components IsNot Nothing Then
                components.Dispose()
            End If
        Finally
            MyBase.Dispose(disposing)
        End Try
    End Sub
    'Required by the Windows Form Designer
    Private components As System.ComponentModel.IContainer
    'NOTE: The following procedure is required by the Windows Form Designer
    'It can be modified using the Windows Form Designer.
    'Do not modify it using the code editor.
    <System.Diagnostics.DebuggerStepThrough()> _
    Private Sub InitializeComponent()
        Me.btnCancel = New System.Windows.Forms.Button()
        Me.btnOK = New System.Windows.Forms.Button()
        Me.Label1 = New System.Windows.Forms.Label()
        Me.Label2 = New System.Windows.Forms.Label()
        Me.Label4 = New System.Windows.Forms.Label()
        Me.Label5 = New System.Windows.Forms.Label()
        Me.Label7 = New System.Windows.Forms.Label()
        Me.TextBox1 = New System.Windows.Forms.TextBox()
        Me.TextBox2 = New System.Windows.Forms.TextBox()
        Me.TextBox4 = New System.Windows.Forms.TextBox()
        Me.TextBox5 = New System.Windows.Forms.TextBox()
        Me.TextBox7 = New System.Windows.Forms.TextBox()
        Me.SuspendLayout()
        'btnCancel
        Me.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.btnCancel.Location = New System.Drawing.Point(235, 240)
        Me.btnCancel.Name = "btnCancel"
        Me.btnCancel.Size = New System.Drawing.Size(85, 30)
        Me.btnCancel.TabIndex = 0
        Me.btnCancel.Text = "Cancel"
        Me.btnCancel.UseVisualStyleBackColor = True
        'btnOK
        Me.btnOK.DialogResult = System.Windows.Forms.DialogResult.OK
        Me.btnOK.Location = New System.Drawing.Point(20, 240)
        Me.btnOK.Name = "btnOK"
        Me.btnOK.Size = New System.Drawing.Size(85, 30)
        Me.btnOK.TabIndex = 1
        Me.btnOK.Text = "Revise As"
        Me.btnOK.UseVisualStyleBackColor = True
        'Label1
        Me.Label1.Location = New System.Drawing.Point(4, 30)
        Me.Label1.Name = "Label1"
        Me.Label1.Size = New System.Drawing.Size(160, 13)
        Me.Label1.TabIndex = 2
        Me.Label1.Text = "Save This Revision"
        Me.Label1.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'Label2
        Me.Label2.Location = New System.Drawing.Point(216+60, 30)
        Me.Label2.Name = "Label2"
        Me.Label2.Size = New System.Drawing.Size(30, 13)
        Me.Label2.TabIndex = 2
        Me.Label2.Text = "sRev"
        Me.Label2.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'Label4
        Me.Label4.Location = New System.Drawing.Point(0, 130)
        Me.Label4.Name = "Label1"
        Me.Label4.Size = New System.Drawing.Size(155, 13)
        Me.Label4.TabIndex = 2
        Me.Label4.Text = "As This Revision"
        Me.Label4.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'Label5
        Me.Label5.Location = New System.Drawing.Point(216+60, 130)
        Me.Label5.Name = "Label2"
        Me.Label5.Size = New System.Drawing.Size(30, 13)
        Me.Label5.TabIndex = 2
        Me.Label5.Text = "tRev"
        Me.Label5.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'Label7
        Me.Label7.Location = New System.Drawing.Point(15+40, 200)
        Me.Label7.Name = "Label2"
        Me.Label7.Size = New System.Drawing.Size(110, 13)
        Me.Label7.TabIndex = 2
        Me.Label7.Text = "Drive for temp files"
        Me.Label7.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox1
        Me.TextBox1.Location = New System.Drawing.Point(30, 51)
        Me.TextBox1.Name = "TextBox1"
        Me.TextBox1.Size = New System.Drawing.Size(166, 20)
        Me.TextBox1.TabIndex = 3
        Me.TextBox1.Text = ""
        'TextBox2
        Me.TextBox2.Location = New System.Drawing.Point(220+60, 51)
        Me.TextBox2.Name = "TextBox2"
        Me.TextBox2.Size = New System.Drawing.Size(30, 20)
        Me.TextBox2.TabIndex = 3
        Me.TextBox2.Text = ""
        'TextBox4
        Me.TextBox4.Location = New System.Drawing.Point(30, 151)
        Me.TextBox4.Name = "TextBox4"
        Me.TextBox4.Size = New System.Drawing.Size(166, 20)
        Me.TextBox4.TabIndex = 3
        Me.TextBox4.Text = ""
        'TextBox5
        Me.TextBox5.Location = New System.Drawing.Point(220+60, 151)
        Me.TextBox5.Name = "TextBox5"
        Me.TextBox5.Size = New System.Drawing.Size(30, 20)
        Me.TextBox5.TabIndex = 3
        Me.TextBox5.Text = ""
        'TextBox7
        Me.TextBox7.Location = New System.Drawing.Point(30+100+40, 200)
        Me.TextBox7.Name = "TextBox2"
        Me.TextBox7.Size = New System.Drawing.Size(20, 20)
        Me.TextBox7.TabIndex = 3
        Me.TextBox7.Text = ""
        'UserInputForm
        Me.components = New System.ComponentModel.Container
        Me.ttHint = New System.Windows.Forms.ToolTip(Me.components)
        Me.AcceptButton = Me.btnOK
        Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
        Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
        Me.CancelButton = Me.btnCancel
        Me.ClientSize = New System.Drawing.Size(340, 300)
        Me.Controls.Add(Me.TextBox1)
        Me.Controls.Add(Me.TextBox2)
        Me.Controls.Add(Me.TextBox4)
        Me.Controls.Add(Me.TextBox5)
        Me.Controls.Add(Me.TextBox7)
        Me.Controls.Add(Me.Label1)
        Me.Controls.Add(Me.Label2)
        Me.Controls.Add(Me.Label4)
        Me.Controls.Add(Me.Label5)
        Me.Controls.Add(Me.Label7)
        Me.Controls.Add(Me.btnOK)
        Me.Controls.Add(Me.btnCancel)
        Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
        Me.MaximizeBox = False
        Me.MinimizeBox = False
        Me.Name = "UserInputForm"
        Me.Text = " NX Manager Revise As  -  By Tip-Eng Member"
        Me.ResumeLayout(False)
        Me.PerformLayout()
    End Sub
    Friend WithEvents ttHint As System.Windows.Forms.ToolTip
    Friend WithEvents btnCancel As System.Windows.Forms.Button
    Friend WithEvents btnOK As System.Windows.Forms.Button
    Friend WithEvents Label1 As System.Windows.Forms.Label
    Friend WithEvents Label2 As System.Windows.Forms.Label
    Friend WithEvents Label4 As System.Windows.Forms.Label
    Friend WithEvents Label5 As System.Windows.Forms.Label
    Friend WithEvents Label7 As System.Windows.Forms.Label
    Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
    Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
    Friend WithEvents TextBox4 As System.Windows.Forms.TextBox
    Friend WithEvents TextBox5 As System.Windows.Forms.TextBox
    Friend WithEvents TextBox7 As System.Windows.Forms.TextBox
End Class
