'Modified on 10 mar 2016
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Module nx_manaqger_save_xpartxrev_as_ypartyrev_xyparts_exist_in_db
Sub Main()
Dim s As Session = Session.GetSession()
Dim lw As ListingWindow = s.ListingWindow
Dim ufs As UFSession = UFSession.GetUFSession
Dim source_master As String
Dim source_rev As String
Dim target_master As String
Dim target_rev As String
Dim windir As String
Dim windrv As String
Dim pdm_master As String
Dim pdm_specs(20) As String
Dim win_master As String
Dim win_specs(20) As String
Dim dsn As String 'dataset name
'create new form object
Dim myForm As New UserInputForm
'Dim myForm As UserInputForm = New UserInputForm(var1)
myForm.DialogSetDefData( "part_B393-01", "-", "part_A193-01", "C", "D")
If myForm.ShowDialog() <> DialogResult.OK Then Exit Sub
If Not myForm.DialogGetUserData( source_master, source_rev, _
target_master, target_rev, windrv) Then Exit Sub
lw.Open()
ufs.Ui.ExitListingWindow() ' Clear and close the window
windir = windrv & ":\" & target_master & target_rev & "\"
pdm_master = "@DB/" & source_master & "/" & source_rev
win_master = windir & target_master & "_" & target_rev & ".prt"
lw.WriteLine("=============================================")
lw.WriteLine("pdm_master = " & pdm_master)
lw.WriteLine("")
lw.WriteLine("windir = " & windir)
lw.WriteLine("")
lw.WriteLine("win_master = " & win_master)
'================ Export to native =================
Try
' Determine whether the directory exists.
If Directory.Exists(windir) Then
lw.WriteLine(windir & " path exists already.")
Else
' Try to create the directory.
Dim di As DirectoryInfo = Directory.CreateDirectory(windir)
lw.WriteLine(windir & " Directory was created successfully at {0}." _
& Directory.GetCreationTime(windir))
End If
' Delete the directory.
'di.Delete()
'lw.WriteLine("The directory was deleted successfully.")
Catch e As Exception
lw.WriteLine("The process failed: {0}." & e.ToString())
End Try
Dim load_status As UFPart.LoadStatus = Nothing
ufs.Clone.Terminate()
ufs.Clone.Initialise(UFClone.OperationClass.ExportOperation)
ufs.Clone.SetFamilyTreatment(UFClone.FamilyTreatment.TreatAsLost)
ufs.Clone.setDefNaming(UFClone.NamingTechnique.Autotranslate)
ufs.Clone.SetDefItemType ("")
ufs.Clone.SetDefDirectory(windir)
'ufs.Clone.EnsureDefDirectory (windir)
ufs.Clone.SetAssocFileRootDir (windir)
ufs.Clone.SetDefAction(UFClone.Action.Overwrite)
ufs.Clone.SetLogfile(windir + "export_clone.txt")
ufs.Clone.SetDefAssocFileCopy (True)
ufs.Clone.AddAssembly(pdm_master, load_status)
Dim prt_cnt As Integer = 1
Dim spc_cnt As Integer = -1
Dim prt_name As String
ufs.Clone.StartIteration()
Do
ufs.Clone.Iterate(prt_name)
If(prt_name = Nothing) Then Continue Do
lw.WriteLine("Export Iterate Part ==>> " & prt_cnt.ToString() & " prt_name = " & prt_name)
Dim names() As String = prt_name.Split("/")
If names(1).ToUpper = source_master.ToUpper Then
If prt_name.ToUpper = pdm_master.ToUpper Then
ufs.Clone.setNaming(prt_name, UFClone.NamingTechnique.UserName, win_master)
End If
If prt_name.Contains("/specification/") Then
spc_cnt = spc_cnt + 1
If spc_cnt < 9 Then
dsn = target_master.RePlace("_", "") & "d" & "0" & (spc_cnt+1).ToString
Else
dsn = target_master.RePlace("_", "") & "d" & (spc_cnt+1).ToString
End If
win_specs(spc_cnt) = windir & target_master & "_" & target_rev & "_s_" & dsn & ".prt"
pdm_specs(spc_cnt) = "@DB/" & target_master & "/" & target_rev & "/specification/" & dsn
ufs.Clone.setNaming(prt_name, UFClone.NamingTechnique.UserName, win_specs(spc_cnt))
End If
End If
prt_cnt = prt_cnt + 1
Loop While (prt_name <> Nothing)
Dim naming_failures As UFClone.NamingFailures = Nothing
ufs.Clone.setdryrun (false)
ufs.Clone.GenerateReport()
ufs.Clone.PerformClone (naming_failures)
'================ Import to Tce =================
Dim cnt As Integer
For cnt =0 To spc_cnt
ufs.Clone.Initialise(UFClone.OperationClass.ImportOperation)
ufs.Clone.SetDefAction(UFClone.Action.UseExisting)
ufs.Clone.SetLogfile(windir + "import_clone" & (cnt+1).ToString & ".txt")
ufs.Clone.AddAssembly(win_specs(cnt), load_status)
prt_cnt = 1
Do
lw.WriteLine("Import Iterate Part ==>> " & prt_cnt.ToString() & " prt_name = " & prt_name)
If prt_name.ToUpper = win_specs(cnt).ToUpper Then
lw.WriteLine("===========================================================")
lw.WriteLine(" win_specs(" & cnt.ToString & ") = " & win_specs(cnt))
lw.WriteLine(" pdm_specs(" & cnt.ToString & ") = " & pdm_specs(cnt))
ufs.Clone.SetAction(win_specs(cnt), UFClone.Action.Overwrite, "")
End If
naming_failures = Nothing
Next
lw.Close()
lw.Closewindow()
msgbox("@DB/" & target_master & "/" & target_rev & " - Clone Done ")
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
End Function
End Module
' User Input Form Dialog Class
Public Class UserInputForm
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
'Add any initialization after the InitializeComponent() call
'TextBox1.Text = "part_B393-01"
'NX icon in top left side
NXOpenUI.FormUtilities.SetApplicationIcon(Me)
NXOpenUI.FormUtilities.ReparentForm(Me)
End Sub
' Returns the data selected on the form.
' All parameters are output parameters.
' This function should only be called after this form has been
' shown to the user and only if the user did not cancel out of
' the form.
Public Function DialogGetUserData( ByRef sn As String, _
ByRef sr As String, _
ByRef tn As String, _
ByRef tr As String, _
ByRef fd As String) As Boolean
If Me.DialogResult <> DialogResult.OK Then Return False
'Throw New System.Exception("Illegal GetUserData calling")
sn = frmSrcMasterValue
sr = frmSrcMasterRevValue
tn = frmTargetMasterValue
tr = frmTargetMasterRevValue
fd = frmWinDriveValue
Return True
End Function
Public Function DialogSetDefData( ByRef sn As String, _
'If Me.DialogResult <> DialogResult.OK Then Return False
frmSrcMasterValue = sn
frmSrcMasterRevValue = sr
frmTargetMasterValue = tn
frmTargetMasterRevValue = tr
frmWinDriveValue = fd
'Return True
End Function
'*************** Private vars **************************
Private frmSrcMasterValue As String
Private frmSrcMasterRevValue As String
Private frmTargetMasterValue As String
Private frmTargetMasterRevValue As String
Private frmWinDriveValue As String
Private Sub UserInputForm_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
TextBox1.Text = frmSrcMasterValue
TextBox2.Text = frmSrcMasterRevValue
TextBox4.Text = frmTargetMasterValue
TextBox5.Text = frmTargetMasterRevValue
TextBox7.Text = frmWinDriveValue
'ttHint.SetToolTip(Me.btnOK, "Revise As")
ttHint.SetToolTip(Me.btnOK, "Save the source master revision As a target master revision" _
& VbCr & "The source master must have a Spec drawing" _
& VbCr & "Both source and target masters exist in NX Manager Data Base" _
& VbCr & "Warning !!! no valid input checking " )
End Sub
Private Sub btnCancel_Click(sender As System.Object, e As System.EventArgs) Handles btnCancel.Click
Me.Close()
End Sub
Private Sub btnOK_Click(sender As System.Object, e As System.EventArgs) Handles btnOK.Click
frmSrcMasterValue = TextBox1.Text
frmSrcMasterRevValue = TextBox2.Text.ToUpper
frmTargetMasterValue = TextBox4.Text
frmTargetMasterRevValue = TextBox5.Text.ToUpper
frmWinDriveValue = TextBox7.Text.ToUpper
Me.Close()
End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class UserInputForm
Inherits System.Windows.Forms.Form
'Form overrides dispose to clean up the component list.
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
Try
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
Finally
MyBase.Dispose(disposing)
End Try
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
Me.btnCancel = New System.Windows.Forms.Button()
Me.btnOK = New System.Windows.Forms.Button()
Me.Label1 = New System.Windows.Forms.Label()
Me.Label2 = New System.Windows.Forms.Label()
Me.Label4 = New System.Windows.Forms.Label()
Me.Label5 = New System.Windows.Forms.Label()
Me.Label7 = New System.Windows.Forms.Label()
Me.TextBox1 = New System.Windows.Forms.TextBox()
Me.TextBox2 = New System.Windows.Forms.TextBox()
Me.TextBox4 = New System.Windows.Forms.TextBox()
Me.TextBox5 = New System.Windows.Forms.TextBox()
Me.TextBox7 = New System.Windows.Forms.TextBox()
Me.SuspendLayout()
'btnCancel
Me.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.btnCancel.Location = New System.Drawing.Point(235, 240)
Me.btnCancel.Name = "btnCancel"
Me.btnCancel.Size = New System.Drawing.Size(85, 30)
Me.btnCancel.TabIndex = 0
Me.btnCancel.Text = "Cancel"
Me.btnCancel.UseVisualStyleBackColor = True
'btnOK
Me.btnOK.DialogResult = System.Windows.Forms.DialogResult.OK
Me.btnOK.Location = New System.Drawing.Point(20, 240)
Me.btnOK.Name = "btnOK"
Me.btnOK.Size = New System.Drawing.Size(85, 30)
Me.btnOK.TabIndex = 1
Me.btnOK.Text = "Revise As"
Me.btnOK.UseVisualStyleBackColor = True
'Label1
Me.Label1.Location = New System.Drawing.Point(4, 30)
Me.Label1.Name = "Label1"
Me.Label1.Size = New System.Drawing.Size(160, 13)
Me.Label1.TabIndex = 2
Me.Label1.Text = "Save This Revision"
Me.Label1.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'Label2
Me.Label2.Location = New System.Drawing.Point(216+60, 30)
Me.Label2.Name = "Label2"
Me.Label2.Size = New System.Drawing.Size(30, 13)
Me.Label2.TabIndex = 2
Me.Label2.Text = "sRev"
Me.Label2.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'Label4
Me.Label4.Location = New System.Drawing.Point(0, 130)
Me.Label4.Name = "Label1"
Me.Label4.Size = New System.Drawing.Size(155, 13)
Me.Label4.TabIndex = 2
Me.Label4.Text = "As This Revision"
Me.Label4.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'Label5
Me.Label5.Location = New System.Drawing.Point(216+60, 130)
Me.Label5.Name = "Label2"
Me.Label5.Size = New System.Drawing.Size(30, 13)
Me.Label5.TabIndex = 2
Me.Label5.Text = "tRev"
Me.Label5.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'Label7
Me.Label7.Location = New System.Drawing.Point(15+40, 200)
Me.Label7.Name = "Label2"
Me.Label7.Size = New System.Drawing.Size(110, 13)
Me.Label7.TabIndex = 2
Me.Label7.Text = "Drive for temp files"
Me.Label7.TextAlign = System.Drawing.ContentAlignment.MiddleRight
'TextBox1
Me.TextBox1.Location = New System.Drawing.Point(30, 51)
Me.TextBox1.Name = "TextBox1"
Me.TextBox1.Size = New System.Drawing.Size(166, 20)
Me.TextBox1.TabIndex = 3
Me.TextBox1.Text = ""
'TextBox2
Me.TextBox2.Location = New System.Drawing.Point(220+60, 51)
Me.TextBox2.Name = "TextBox2"
Me.TextBox2.Size = New System.Drawing.Size(30, 20)
Me.TextBox2.TabIndex = 3
Me.TextBox2.Text = ""
'TextBox4
Me.TextBox4.Location = New System.Drawing.Point(30, 151)
Me.TextBox4.Name = "TextBox4"
Me.TextBox4.Size = New System.Drawing.Size(166, 20)
Me.TextBox4.TabIndex = 3
Me.TextBox4.Text = ""
'TextBox5
Me.TextBox5.Location = New System.Drawing.Point(220+60, 151)
Me.TextBox5.Name = "TextBox5"
Me.TextBox5.Size = New System.Drawing.Size(30, 20)
Me.TextBox5.TabIndex = 3
Me.TextBox5.Text = ""
'TextBox7
Me.TextBox7.Location = New System.Drawing.Point(30+100+40, 200)
Me.TextBox7.Name = "TextBox2"
Me.TextBox7.Size = New System.Drawing.Size(20, 20)
Me.TextBox7.TabIndex = 3
Me.TextBox7.Text = ""
'UserInputForm
Me.components = New System.ComponentModel.Container
Me.ttHint = New System.Windows.Forms.ToolTip(Me.components)
Me.AcceptButton = Me.btnOK
Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
Me.CancelButton = Me.btnCancel
Me.ClientSize = New System.Drawing.Size(340, 300)
Me.Controls.Add(Me.TextBox1)
Me.Controls.Add(Me.TextBox2)
Me.Controls.Add(Me.TextBox4)
Me.Controls.Add(Me.TextBox5)
Me.Controls.Add(Me.TextBox7)
Me.Controls.Add(Me.Label1)
Me.Controls.Add(Me.Label2)
Me.Controls.Add(Me.Label4)
Me.Controls.Add(Me.Label5)
Me.Controls.Add(Me.Label7)
Me.Controls.Add(Me.btnOK)
Me.Controls.Add(Me.btnCancel)
Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
Me.MaximizeBox = False
Me.MinimizeBox = False
Me.Name = "UserInputForm"
Me.Text = " NX Manager Revise As - By Tip-Eng Member"
Me.ResumeLayout(False)
Me.PerformLayout()
End Sub
Friend WithEvents ttHint As System.Windows.Forms.ToolTip
Friend WithEvents btnCancel As System.Windows.Forms.Button
Friend WithEvents btnOK As System.Windows.Forms.Button
Friend WithEvents Label1 As System.Windows.Forms.Label
Friend WithEvents Label2 As System.Windows.Forms.Label
Friend WithEvents Label4 As System.Windows.Forms.Label
Friend WithEvents Label5 As System.Windows.Forms.Label
Friend WithEvents Label7 As System.Windows.Forms.Label
Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
Friend WithEvents TextBox4 As System.Windows.Forms.TextBox
Friend WithEvents TextBox5 As System.Windows.Forms.TextBox
Friend WithEvents TextBox7 As System.Windows.Forms.TextBox
End Class
