JoelTXCive
An existing wastewater treatment plant’s intake headworks are being remodeled.
We are closing off a small wall section in the headworks of the plant. The wall section is only 2ft wide by 4ft tall. Structurally, we can dowel in all around the opening, and then mirror the existing wall’s reinforcing.
My question is on waterproofing the joint? How can I best do this?
I was thinking we could ‘grind in’ a notch into the existing concrete and then grout a rubber waterstop of some sort. I have not seen a detail on this procedure, so am not sure it would work.
Maybe just having a cold joint would be sealed enough? I really do not know.
Any input on the joint would be appreciated.
Thank you.
Thank you.
