Most jurisdictions/health department will have requirements on well siting. You have to first comply with that. Next, theres the whole issue of your conceptual ground water model. If you are extracting water from a confined aquifer, that's a different dynamic then from a water table aquifer. For the former, surface water interaction is not often the big factor; for the latter, it can be a big factor. In water table aquifer conditions, I'd consider the well-head protection area and to what extent the flowing stream could favorably or unfavorably contribute to the water quality.
f-d
¡papá gordo ain’t no madre flaca!
