Water Hammering 1
CNoronha
QA
What do you mean by Water hammering when a check valve is used in a pipe line
improperly designed use of check valves is one of the main contributors to hydraulic transients, the slang name being watter hammer.
BobPE
Suggest you read ARD Thorley's Fluid Transients in Pipelines or go to and check out their technical papers on dynamics and selection of check valves
Sharing knowledge is a way to immortality
When a column of moving liquid (water?) (usually quickly) is suddenly stopped (the likes of a check valve - some worse than others)the energy of this column reverberates (back and forth) along the pipe line until dissipated - "hammer" is the result - much banging and crashing.
Usually a rethink of design as opposed to arrestors(like shock absorbers) is the go
