The method for calculating the flow rate of liquid through a pipe from the pressure drop across it requires an iterative procedure. It is easy, but tedious. You could use the web site referred by BigInch and find the answer by guessing flowrates until you get the known pressure drop. I will give you the steps here, but I suggest that once you get an answer you visit the site recommended by BigInch to validate your answer.
The first formula you need is known as Darcy-Weisbach. I have re-arranged it here from the usual form to give you the flowrate.
Q = 3.51 x 10
5 x [√](( [Δ]P x D
5 ) / ( [ƒ] x L x [ρ] )) {Eq 1}
where
Q is flowrate in liter per second
[Δ]P is the pressure drop over the pipe in bar (= 3 bar)
D is the pipe inside diameter in meter (= 0.1023 m)
[ƒ] is the Moody friction factor (see below)
L is the pipe length in meters (not given)
[ρ] is the fluid density in kg/m
3 (= 1000 kg/m
3 for water)
All of the terms on the right hand side of this equation are known, except for the Moody friction factor [ƒ]. In order to calculate this you kneed to know the Reynolds number, and strictly you need to know the pipe roughness as well.
The Reynolds number is calculated (in volumetric rather than velocity terms) as
Re = 1.27 x [ρ] x Q / ( [μ] x D ) {Eq 2}
where [μ] is the viscosity in centipoise (= 1 cP for water)
The Moody friction factor can be estimated for clean commercial pipe using the Drew, Koo and McAdams equation. This is not as accurate as the Churchill equation, but has the advantage that it does not require the pipe roughness.
[ƒ] = 0.0123 + 0.754 / ( Re
0.38 ) {Eq 3}
Now we have all the formulae and we can outline the solution procedure
Step 1 - guess a Moody friction factor, say 0.015
Step 2 - Calculate Q using Eq 1
Step 3 - Calculate Reynolds number using Eq 2. If Re < 4000 then flow is not turbulent and revert to method for laminar flow given by danw2
Step 4 - Calculate Moody friction factor using Eq 3
Step 5 - If calculated friction factor is different from previous value then apply new value in Step 2 and repeat until Q and [ƒ] stop changing within the required accuracy.
Katmar Software
Engineering & Risk Analysis Software
