Hi fellows,
As3600 wall Vuc depends on the H and Lw. I understand that H is from wall base to top slab. However, I am not sure what H should I use when there is a change in wall configuration?
For example, say I have this wall that is 7.5m long at ground level while 3.5 at level 1 & 2.
What are the corresponding H for Vuc at ground floor Vuc0, at level 1 Vuc1 & level 2 Vuc2?
For example, at ground floor should I separate the wall into a 3.5m long wall and 4.0m long wall with H=9m for the 3.5m long one and H=3m for the 4m long wall one?
