Thanks for your reply EP,
The question has arisen from a poster looking for viscosity data on SAE 30 oil so we are well within the range of the simplified ASTM D341 equation and the discrepancies are not small ones.
Now, while I appreciate that a relationship is at best an approximation of the real world, and though ASTM D341 has proven a very practical and workable equation, it is not an exact description and has limitations as to how it may be interpolated or extrapolated.
So it has its limitations, as Riemschneider and others point out.
Now I have always used it as a very good model when used with care.
My problem is that in reply to a post in the Pipeline forum, a poster has suggested the spreadsheet downloaded here:
I fully expect that extrapolation will give problems, especially when extrapolating to lower temperatures, but when I compare the results of this spreadsheet to the ASTM D341 spreadsheet I produced (and to the results from other ASTM D341 spreadsheets, so it isn't my spreadsheet in particular), about the only points they agree is on is at the two temperatures I selected from the Xlrotor spreadsheet (100
and 220[°]F) and everywhere else the disagreement is major, not just a bit one might expect from two different models of the same data.
I could have used Va and Vb of course, but I don't think that would make any difference.
This gives me pause to ask "do lubricants not obey the same relationship as other hydrocarbons?"... which I find hard to believe.
None the less, I have to consider if the conditions under which I use the ASTM D341 equation (for purely practical reasons), are perhaps almost special cases which minimise the effects of measurement and calculation errors (which is of course true, but surely not to this extent?), and that maybe my experience of ASTM D341 is like a stopped clock... right twice a day i.e. right only under the conditions at which I use it.
But if I am wrong then so too are a number of others such as Tribology-abc.com and others who all seem to use ASTM D341.
xlrotor uses the expression:
V
s=V
a*EXP(LN(V
b/V
a)*(T
s-T
a)/(T
b-T
a))
Where V
s is the viscosity at T
s
and V
a is the viscosity at T
a
and V
b is the viscosity at T
b
Viscosity is cSt and temperature is [°]F
I might accept that other models might be more suitable for extrapolation into low temperatures but between the two reference temperature viscosities I would hope to see some correlation and this is lacking.
So.....? Well either the xlrotor calculation is wrong (not just in the extrapolation but interpolation also) or it describes lubricants better than ASTM D341.....Is there another option?
JMW
