duafar,
Is the strengthening application for increasing the beam-shear capacity of an RC beam, bridge girder, wall, column?
Vertical post-tensioning is occasionally used in bridges where the webs of box girders need additional shear reinforcement and crack control.
Need a bit more info from you - is this an EXTERNAL vertical PT application? Describe the situation a little more and I will see if the papers I have are relevant.
