Hello All
We have venturies installed on over feed and tailing lines (water or oil containing solid contents 10%-15%)and we use seal type D/P transmitters to go with these venturies. Initially we installed these venturie horizontally (3'O clock position) but then the sludge started to accumulate around the seals and resulted in false reading. Now we want to tilt the venturies at or around 1'O clock or 2'O clock position to avoid sludge accumulation. Is it a good idea or we will be compromising flow accuracy. Please respond.
