Vapor properties for FC-72
rory381
Does anybody know where I can find vapor properties for FC-72?
Rory
thanks 25362, but I've already downloaded this calculator. Unfortunately I need Cp_vapor and k_vapor.
P.S. I searched on google for over 1-1/2 hrs!!! Starting to think I found something not available online.
Thanks,
Rory
May I suggest you look around searching for tetradecafluorohexane or CAS #355-42-0 or Flutec PP1 ? Good luck. [pipe]
I have the PFE and HFC property calculator from 3M. Unfortunatly it has NA under many of the vapor properties, go figure. Here's a contact I have on this spreadsheat at 3M:
Lew Tousignant of the 3M Company. He can be reached at 651 736 5242.
He might be able to supply info, 3M's web site is convoluted at best.
Brian
