someguy79
- Apr 5, 2007
- 133
I have a few brass bodied valves with threaded inlet connections. The inlet connections are leaking.
The application where they're used requires them to hold pressures of 0-300 psig at temperatures ranging from ambient to -200F.
I have not been able to confirm with the plant operators whether or not any sealant was used on the threads. I expect that none was used. Because of the outlet connection needed, only certain positions (every 90 degrees) can be acheived for tightening down the valve body.
The knee-jerk solution is to tape the threads with teflon tape or similar material, but I've come across a few cautionary tales about tapes and puttys. Apparently, typical white teflon tape will creep and squish out over time. eventually it will not provide a good seal. (or so the story goes)
I'm also concerned that because the coefficient of thermal expansion is so much greater for the teflon than either the brass valve body and 304L pipe. It might shrink more than the metals and cause leakage to be worse.
Can anyone provide examples of similar situations, and how it was dealt with? What (if any) sealing materials might be able to alleviate this problem?
