Following is the technical specifications of vacuum contactor in which I have some questions.
1.Does it mean that the protective relays can be used to trip the vacuum contactor till 12,500A?, then why Maximum break capability is mentioned as 8000A?
2.What is the difference between the interrupting current and breaking current? I thought the two terms were same, but here it is mentioned with different rating
3.In Some other specification, I find "Maximum Interrupting current (3 operations)"- does it mean, the contactor can interrupt only for 3 times at the interrupting rating.What exactly does it mean?
4. What is the difference between the SC withstand rating and short time current rating capability?
