I've got a bit of a problem that I need some serious direction on. I have not been involved directly in the following but it will be falling in my lap very soon and I have several reservation about it.
We have a used rotary vacuum dryer that we intend to use in an upcoming project. It's about 20 ft long and 5 ft in diameter just to give you a scale. Originally rated for 150 PSI on the jacket I believe, FV inside the dryer.
The jacket of the RVD was in very rough shape when we received it. Badly corroded along the bottom half. A welding contractor was brought in and they cut away several of the weak area. Sheets of steel were then rolled and welded on to the old jacket, basically covering the entire bottom half of the dryer.
I'd questioned the powers that be about if the welders were code stamped to do these repairs. To be blunt, the response was "There were patches already on the jacket and no R stamp present, so it doesn't matter. Don't worry, we will only have 15 PSI on it".
I've been asked to hydrotest the jacket, I feel confident I can accomplish this task safetly. They are intending to have an operating pressure of 15 PSIG steam on the jacket. However, since our steam supply is at 100 PSIG, I intend to hydro it upto at least 100 PSIG with the justification that the regulator could fail.
SO.... can you (legally) use a repaired vessel to hold low pressure steam at 15 PSI with out an R-Stamp?
Can you use a vessel completely missing the National Board number to hold steam at 15 PSI?
Can you get a pressure vessel approved by the National Board after the fact or do all repairs have to be done by a coded shop?
I am sorry I am not well versed on ASME codes, but I just feel this is not wise. If you can point me in the direction of some good resources on the subject I would be much appreciative.
Please feel free to be blunt. I am not pleased about the situation, though no one else seems to be too overly concerned.
