Using Text in tables. 1
Darrylh
4
Can you add Bold to certain parts of text in a table you have put on a drawing? I know when you use Solidworks you can use the %% and a letter and it adds symbols. Is there something similar in Solid Edge.
For symbols I think you can use the unicode key-in such as ALT+0176 (keep ALT key down and key in 0176)
I don't think there is any control over individual cells as the text is governed by whatever style is set. You can however change the style for all cells and column headers.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Hi Darrylh,
See attached file, these "codes" work on annotations and dimensions, I think that they are availiable on table...
Best regards
MERMET Sebastien
Mecanical & Product Designer
SolidEdge ST2 & Unigraphics NX4 & 6
Dell precision 490 & Dell precision M6300
 http://files.engineering.com/getfile.aspx?folder=df305de9-6cf1-4b55-aabc-f8900af2d281&file=SE_Symbols_Code.pdf
If you embed an Excel sheet you can use all the formatting available in Excel.
Terry
Though you run the risk of all sorts of other problems with the embedded Excel unless that's been fixed in the ST releases.
Kenat,
I have found that keeping the excel spreadsheet in the same directory as the draft works well.
You can't re-crop an excel sheet to see a larger area once it's been placed on a draft sheet, so if you add a load of data it may not be visible.
This apparently is a Windows problem not SE.
You can get round it by having data in a cell way outside the required area. You will then be able to enlarge the cropped area at least as far as that cell.
bc.
Quadro FX4600.
Of course, Excel files work a lot better than embedded word files.
