Using Section I for Design & Construction of Heating Boilers.
IdanPV
497
Hello all,
Is there any option (Code Case, Interpretation or Paragraph in the Code) which allow a Section I stamp holder to do Section IV jobs?
What I want to know if there any way that a manufactorer which have an "S (or E) stamp" will use his S stamp for Section IV jobs.
See ASME I, PG-2.2 below
ASME I
PG-2 SERVICE LIMITATIONS
PG-2.1 The rules of this Section are applicable to the following services:
(a) boilers in which steam or other vapor is generated at a pressure of more than 15 psig (100 kPa) for use external to itself
(b) high‐temperature water boilers intended for operation at pressures exceeding 160 psig (1.1 MPa) and/or
temperatures exceeding 250°F (120°C)
PG-2.2 For services below those specified in PG-2.1 it is intended that rules of Section IV apply; however, boilers for such services may be constructed and stamped in accordance with this Section provided all applicable requirements are met.
Regards - Juergen
Hello fleischfresser,
Thank you very much!
