Using find function to find a single inverted comma in a cell 2
AU
How do I do this?
I want something like =FIND(""",A2,3) which of course does not work ... any ideas?
Read the Eng-Tips Site Policies at FAQ731-376
=FIND("'",A2,3) works for a single inverter comma
=SEARCH("""",A2) will find the first " character
Thanks Francis, the search one worked perfectly :)
What is the key difference between find and search? It seems like search is just a simpler version of find (i.e. it finds just one character rather than a string)
From the Excel Help
"FIND finds one text string (find_text) within another text string (within_text), and returns the number of the starting position of find_text, from the first character of within_text.
You can also use SEARCH to find one text string within another, but unlike SEARCH, FIND is case sensitive and doesn't allow wildcard characters."
Ahhh cool, seems a bit weired having two things which do essentially the same thing but for a few options ... probably a historical thing.
Hi ColurfulFigsnDiags:
As FrancisL has stated ...
Yogi Anand, D.Eng, P.E.
Energy Efficient Building Network LLC
ANAND Enterprises LLC
Yogia, I understand that, but essentially they are the same function i.e. FIND is a subset of SEARCH ... the only difference between the two is a few options which could be included within the function itself.
Forinstance you could have =SEARCH([search text],[search cell],[case sensative(True/false)], [Allow Wildcards (True/false)]) and you would have exactly the same things as FIND. So therefore the only reason I can imagine having the two is to allow backward compatibility.
