Use of composite geometric positional tolerancing on cylindrical surfaces 1
Tunalover
Is this possible? I see cases where a hole pattern can float as a group on a cylindrical surface but the in-pattern positional tolerance must be controlled to insure fit. How would one establish a datum reference frame for this scenario? TIA.
Bruce
Tunalover
A sketch could help. Can you post anything?
pmarc-
I'm not at work and won't be in the foreseeable future so I have no sketcher or CAD system to use to generate a sketch. My scanner is also on the blink so I can't provide a hand sketch either.
Just think of a hollow pipe with a pattern of holes evenly spaced (same angular spacing apart) around the perimeter. The same "z-dimension" would apply to each member of the group but in a general sense I suppose it may not have to be that way.
Tunalover
Just what the doctor ordered. Thank you pmarc!
Tunalover
