Unhiding worksheets 2
boottmills
90
Is there a way to unhide multiple worksheets at once as opposed to one at a time?
Boottmills
In Excel 2003 there appears to be no command available through the menus. However, I have a VBA macro as part of an "auditing" workbook that unhides all hidden worksheets:
Sub showAllSheets()
Dim sheet As Object
Application.ScreenUpdating = False
For Each sheet In ActiveWorkbook.Sheets
sheet.Visible = True
Next sheet
End Sub
With some more work you could have a similar command that would load a dialog with a selection list which would list all of the hidden worksheets and then allow you to select multiple sheets to unhide at once.
Hi boottmills:
Picking up from TomBarsh, ... how about unhiding say Sheet6, Sheet7, and Sheet9
Code:
Sub y_1a()
        For Each sh In Sheets(Array("Sheet6", "Sheet7", "Sheet9"))
            With sh
                .Visible = True
            End With
        Next
End Sub
Would this work for you?
Yogi Anand, D.Eng, P.E.
Energy Efficient Building Network LLC
ANAND Enterprises LLC
You may also install a utility like ASAP ( that'll have a menu command for it.
Cheers,
Joerd
Sirs,
These both work fantastically! Thank you very much!
Boottmills
