Unfold / Flat Pattern 1
spadazenon
GR
Dear All,
I could use your help to create a flat pattern feature of sheet metal body. I can't figure out how to make it flat, hence it is a surface with thickness of 1mm.
I have tried "global shaping" and "flat pattern" without any success. I don't have a advanced sheet metal licence.
Best regards,
spada
 http://files.engineering.com/getfile.aspx?folder=485c3ef1-8831-4cff-9985-fd5dca904f54&file=sides.zip
if you still have NX4 installed, you could try fabric flat pattern to give you something close.
Sorry ... I've had a quick go but not been able to.
It strikes me however that this is probably not a 'sheet metal' part. It looks more like a 'pressing'.
If you try and flatten it you would effectively buckle somewhere in the middle or tear the corners.
Jon
Had no problem creating a flatpattern with the new flattening tool in NX11.
Thank you all for your answers,
Jon, yes it would probably buckle somewhere in the middle, that it is why I couldn't unwrap it. It was telling me that the shape was not developable.
Petulf, I am currently using NX10. Hope we can upgrade in the near future.
I haven't been able to unwrap it until now. From what I understand there is no way (or there is a difficult one) to unfold/unwrap a non developable face without an advanced module.
Brgds,
Spada
The new flatten tool in NX11 requires a studio license.
Robnewcomb, in NX10 it says that I need an "NX composite or Advanced Sheet Metal Licence" to use Fabric Flat Pattern.
Lockdain, this tutorial is very handy, but unfortunately it works only for "developable" surfaces.
Lockdain, thank you for your response, but I couldn't use it because I don't obtain the needed licence.
Took another stab at it, this time using only basic modeling tools, see enclosed zip file for nx10 prt.
You might try using Insert > Sheet Metal > Metaform to flatten this part. It's UI is a bit odd, be forewarned.
@petulf
This was a very nice approach. I will follow your steps. Thank you very much for the model.
