HighPressureProfessor
I am looking for some general insight on the function of “knife” edge Air Seal Serrations in Gas Turbines.
I have recently stumbled upon two components in the same High Pressure Rotor Section of a Gas Turbine engine, both of which are capable of maintaining engine service parameters while missing material (blends) from their Air Seal Serrations.
The difference is one component has a limitation for the number of serrations that can have missing material in line axially, while the other does not.
There are a total of 12 Seals with axial limitations that control the CPD Air Flow through the High Pressure Rotor Section. There are a total of 2 Seals without axial limitations which prevent leakage of cooling air needed for the rotor blades that receive the heated gas directly from the combustion system.
My questions are:
If the seals are meant to cut into an abradable material to effectively act as a narrow labyrinth to slow air flow, why do some components allow for axial in line blends while others do not?
Is there a way to quantify the amount of “leakage” for 2 serrations with blends axially in line versus 2 serrations with blends separated by X amount of circumferential distance?
This is my first post and I have only been in in the Gas Turbine Analysis field for a little over a year. Any general concepts or mentoring on Seal Serration Air flow would be IMMENSELY appreciated.
Cheers,
HPProfessor
My questions are:
Cheers,
HPProfessor
