UG minimum requirements
tooldeziner
Aerospace
I am planning to have a computer built specifically to run UG at home. Would appreciate any suggestions as to minimum requirements, pitfalls, do's and don'ts, etc.
If the machine is being used full time for CAD work. then I would go with a pre-configured certified workstation.
Options on a certified machine would be a higher memory graphics card and more computer memory.
If the machine will only be used on part time for CAd work, then you can look at the components in a certified machine and configure one like that.
Just remember that if you have any problems at all with NX on a non-certified machine, GTAC can refuse all calls for help. They usually won't if they can reproduce the error on a certified machine, but they can.
Ben Loosli
Sr IS Technologist
L-3 Communications
Thanks for the input, guys. I am still a little uncertain what to do.
Do I have to buy a "certified machine" directly from UGS?
I will be using a "portable license" from my employer to work at home.
Ok...
I have the following at home:
P4 3.4GHz, 2 GB RAM, and a GEFORCE 6800GT.
no need for quadro, and I've worked on assmblies with thousends of parts.
the importent things are:
mid-high level CPU, at least 1 GB RAM, preferably 2, and a GOOD opengl graphics card.
quadro is not necessary, but if you are going on gaming cards, then the high-end nvidia cards are better.
if you can get your hands on a geforce 6800GT or ultra, they can be software-modded to quadro.
UGS does not sell hardware. Their website lists various machines from Dell, IBM, HP, Sun and others that are certified.
For sporadic work at home, I have a Dell XPS with 2GB memory and an ATI Radeon 9800Pro that works fine for UG and Pro/E.
Ben Loosli
Sr IS Technologist
L-3 Communications
We benchmark machines and more recently the HP 64 bit range. I'd suggest the HP 9400, either AMD (Cheaper and faster) or intel duo. Good value for money. Always go for a UGS supported machine building your own isnt good in the long run. Also the ATI 7300 is a rather cool card!
A revised note:
got the dell 390 workstation today at work... it's certified and a real killer :)
