U-bend Tubes post bending heat treatment
Shayan Zariean
Materials
Jul 24, 2019
8
Dear Readers
I have bent Carbon Steel (A179) (2.11 mm Thickness) tube and there is requirement for post bending stress relief due to Sulfide stress cracking. based on UCS-56 the minimum soaking time at maximum temp. is 15 minutes, bu at UCS-79 it is mentioned that it is possible to change soaking time for less than 6 mm thickness if it is sure that all thickness is in the same temperature. so I want to know what is the soaking time for u-bend of carbon steel tube with 2.11 mm thickness? 15 minutes or lesser?
besides i have the same question for solution annealing of Stainless Steel (SS316 and SS321) tubes with the same thickness. How much soaking time is enough for Solution Annealing of these tubes?
Please don't multiple post
