Dear Experts,
If we drill tubesheet for blind tapped hole for pulling out bundle. Should we plug with bolt this blind tapped hole.
ASME Section VIII UG-43(d) states "The distance from the inside sur-face of the vessel to the bottom of a drilled hole to be tapped shall not be less than the corrosion allowance plus
one‐fourth of the minimum required wall thickness."
and UG-43(g)states details of studs. It is unclear that can we leave this tapped hole without plugging?
Thanks,
Thanks,
