Hi all,
I have a situation where a component is deformed during the assemblyprocess between subassembly and final assembly.
This means the subassembly should show a different geometry as the final assembly
I added both geometries in one NX part file creating a reference set for each.
But is seems I cannot force NX to use refset#1 in the subassy and refset#2 in the finalassy
When I change it at one level the other level automatically follows.
Does anyone know if this is a setting which can be changed?
Alternative could be to use arrangements, but as far as I can tell , different arrangements can show different component positions, not different component geometries
Is this correct?
thanks
PS. using NX8
Is this correct?
thanks
PS. using NX8
