Truss Top Chord Lateral Support 1
hoshang
IQ
Hi all,
For a Pratt truss, lateral support is provided by a transverse U-frame consisting of the floor beam and truss verticals. What about a Warren truss? It doesn't have verticals.
Hi BA,
I meant can points A and B in this image be considered as support points?
or these points (my A and B) can be assumed as one point so that there would be 3 points of support: one at each end and one at the middle so it can mimic the analysis model (a two-span truss supported by three points)?
Your points A and B are necessary supports. So there are four supports in total.
The middle truss acts like a doubly cantilevered beam with a truss reaction R at the end of each cantilever. See below.
Hi BA,
My thought is this
analytically maybe represented by this for simplicity (i.e., two hinges and two rollers):
Am I right?
My query is what would mimic this (i.e., two rollers and one hinge):
Hi BA,
My thought is this
Yes, that would be possible.
Am I right?
  1. Two rollers and one hinge would be possible, but a pinned support would need a stiff column below it, fixed at the base and pinned at the top. A pin can't exist by itself.
  2. The entire structure would deflect with the column in addition to temperature movement.
  3. Each truss would span 90' instead of 60', so the trusses would use more steel.
  4. Erection would be considerably more difficult without a middle truss held in place while erecting the two exterior trusses.
post #38
BAretired states:
If there is sufficient clearance for road widths, I suggest the vertical leg of the orange Tee be 2 panels wide. Alternatively the orange truss should be modified, or a different concept should be considered.
Can you elaborate more on the your red phrase? BTW how would you reference to my posts? I tried it without success.
post #38
No, I will not elaborate! The information you must provide are:
  • the required vertical clearance under the bridge to allow the passage of vehicles.
  • the required width of road.
  • the required separation of roads.
I do not understand your last two sentences about referencing your posts. What do you mean?
20ft
45ft
12ft
I meant when you quote my posts:
Your query has been answered in an earlier post! The structure below is equivalent to one pin (middle) and one roller each end. But the overall length of trusses does not have to be 180'. it has to be only 65+12+65 = 142'. Two 71' trusses would seem to be sufficient. There is no need to make them continuous; they could each be simple spans with a short cantilever at the middle. Then, if some clown collides with one truss, it can be replaced without disturbing the other.
