Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Yes, that would be possible.Hi BA,
My thought is this
analytically maybe represented by this for simplicity (i.e., two hinges and two rollers):
Am I right?
My query is what would mimic this (i.e., two rollers and one hinge):
Can you elaborate more on the your red phrase? BTW how would you reference to my posts? I tried it without success.BAretired states:
If there is sufficient clearance for road widths, I suggest the vertical leg of the orange Tee be 2 panels wide. Alternatively the orange truss should be modified, or a different concept should be considered.
No, I will not elaborate! The information you must provide are:post #38
20ftBAretired said:
- the required vertical clearance under the bridge to allow the passage of vehicles.
45ftBAretired said:
- the required width of road.
12ftBAretired said:
- the required separation of roads.
I meant when you quote my posts:BAretired said:
I do not understand your last two sentences about referencing your posts. What do you mean?
Okay hoshang,
First, the red text:
I meant that if any of my suggested supports interferes with the plan, something must change. Looking at the new information, it now appears that something must change.
Let's see...20' clear height, 45' road width and 12' separation of roads.
The geometry has changed. You do not need 90' spans to cross a 45' wide road. A two span bridge, each span about 50' or 60'with a 10'x12' platform at midpoint could be used instead. A 20' high stair is required at each end.
The dimensions have changed, but the concept is still the same. In theory, one pin and two rollers would mimic the structure we had before. But I prefer a rigid support structure in the middle, particularly with such a high clearance between road and bridge. Deflection parallel to the trusses should be minimized.
