I'm working on a project where some beams were not coped properly for some connections and need to be modified. The contractor would obviously like to torch cut the steel in the field rather than send them back to the shop.
I have been trying to find out why it is normally not recommended to field torch steel. Almost every spec I've ever seen has verbiage to this effect in it. As far as I can tell, it is more for the quality of workmanship typical of field cutting than any mechanical reason (heat effects on the steel, stresses induced from torching, etc.). Is there any reason anybody is aware of that we would not want the beams torched in the field?
