davidbeach
- Mar 13, 2003
- 9,528
I may have asked this before, but if I did I never got a workable answer so I'll try again...
I need to work with times to the nearest millisecond (and can foresee microsecond times at some point in the future) as I establish times and reference times for events on the electric grid. I can apply a cell format of HH.mm.ss.000 and have the full time displayed. That part works fine. What doesn't seem to work is the ability to edit that number. If I try to edit, either in the cell or in the entry area above the spreadsheet, excel (2010) rounds the time to the nearest HH.mm.ss. I always have to retype the milliseconds portion. Sometimes that's easy enough, add the dot and three digits. Other times it's a true PITA; I'm presently working on events that occurred in the last half second of 9:59:59 - if I want to edit 9:59:59.587 and change it to 9:59:59.592 I have to reenter the whole thing because hitting edit causes 9:59:59.587 to become simply 10:00:00.
Is there some way, some setting, to cause excel understand that time has far finer gradations than seconds? I deal in fractions of electrical power system cycles and there's 60 of them (ideally, where I am) every second. One cycle is 16.667 milliseconds. One degree is 46 microseconds. If I deal with traveling waves, 1 microsecond is 1000 feet; the nearest second is many times around the earth.
Is there some way to force excel to work in time units considerably smaller than a second? Or, am I simply stuck with the brain dead units of time that I seem to be stuck with?
