I have a question about terminology/naming of some branch connections I'm sure are very familiar to all of us. I'm also guessing that my company is not the only having experienced this problem.
The problem: receiving what Penn Machine ( calls a 'weld boss' in place of a 'threadolet' ( The 'weld boss' appears in real-life to have been machined from a forged coupling as the O.D.'s match for both fittings, and both coupling and 'weld boss' are made of the same materials, typically. The 'threadolet' (or sockolet) is made to the MSS-SP-97 standard.
An advantage of the 'weld boss' is a smaller required thru-hole in the run piping, and this is the advantage that we are after. (We have enough reinforcement in the wall of the 'weld boss'.)
My question: It appears that these 'weld bosses' have quite a few names. Is there a 'proper' name associated with an ASME, ANSI, or MSS-XX code for this beast? I am fighting a battle on a couple of fronts: our vendors are obviously confused, our shipping/receiving dept. needs some training on the differences, and we need to requisition them with some sort of standard methodology to consistently receive one or the other.
There are many different names for threadolets and the like as can be seen by comparing what McMaster, Grainger, and the other vendors/manufacturers mentioned above call the same item.
Fitter, happier, more productive
