Scott231us
Good day.. i have an ABS plastic enclosure that is approx 100mm long. There is a round hole (for bolt) in the middle that is 5mm diameter. If a 100mm long piece of plastic expands 0.3mm in hot arizona weather or reduces 0.3mm in freezing temps, how much does this effect the diameter of the 5mm hole? Will the 5mm hole change the same amount (plus or minus 0.3mm) in the middle of the 100mm long enclosure), or only a fraction of that plus or minus 0.3mm expansion / reduction applies to the smaller 5mm diameter hole? Need to understand how this will effect bolt hole tolerances..
