I have an 8" ID ring made from 8620. The ring was case hardened to approximately Rc55 and ground to final dimensions. We made note of these dimensions at inspection of the part.
The ring fits over a shaft which is made from 4130 and was also case hardened and ground to size. There is approximately .0005 diametral clearance between the ring and shaft.
The shaft is heated internally with an electric heater to a working temperature of 400F. This was done about 5 times in the testing of our machine. We also measured the temperature of the ring during heat-up to assure that it heated along with the shaft (which it did within about 15-20F).
After dis-assembly we are finding that the internal diameter of the ring has grown .008" resulting in a loose wobbly fit on the shaft.
I don't see any evidence of wear (and there is no relative motion of ring and shaft, anyways). Can a steel part not return to original dimensions when heated and cooled? I am aware of some warp occurring after heat treat operations, but I don't see such a drastic dimensional change at only 400F as making any sense.
What mechanism could explain this?
