I want to machine the inside of a copper ring. Therefore, I want to clamp the ring (diameter 25 mm, length 6 mm) around its outside by making aluminium clamping part. By heating the aluminium clamping part, assembling the ring in the clamp and cool down, both are fixed. My question is: how can I calculate the clamping force if the outer diameter of the ring is slightly bigger than the inside diameter of the aluminium clamp?
