dgeesaman - "That photo feels implausible to me, especiall with the groove depth barely reaching the centerline of the o-ring body"
I am on the fence over whether I should post a more complete photo of the example I offered to counter your skeptical remark but the full geometry is part of a proprietary design, so no. The small section of the seal geometry I show works for a device that must maintain a seal with exposure to biological fluids at 300 psi and compatible with autoclave sterilization, and compatible with exposure to laboratory disinfectant solutions. Does this work for 3000 psi hydraulic systems? No. As I stated, the the OP has not said what is their sealing conditions and environment only they need an o-ring with 'tight tolerances'.
