Text 2
OnTheJob
ZA
guys how do one put a boundary a round text. One can do it for dims.
for mtext and text, you can use "tcircle" from the Express Tools. But for dims...?
Maybe you can find a lisp in the www.
Lothar
ADT 2004
ACAD 2002
OnTheJob,
I saw, that you have started some threads, but you never reply, how the problems have been solved...[thumbsdown]
ADT 2004
ACAD 2002
sorry about that. it will not happen again. I usually just follow what the other guys say and it works. ;-)
Dims is easy - there is a switch for it in DDIM
Text is also easy - inthe express tools pull down menu go for text and "enclose text with object". Or use tcircle, which is the routine that the pulldown runs
DDIM > Modify > Text > Draw frame around text
____________________
Acad2005, Terramodel
I have never noticed that...!
1 star
L.
ADT 2004
ACAD 2002
It used to be called making a dimension a "Primary" dimension and the Setvar has been changed to DimGap. Setting dimgap to a negative number makes the box appear. You can type dimgap on the command line and set it to whatever you want. Paly and have fun.
thanks guys works fine, but it is not part of the text (same as drawing a circle around the text manually).
