1
- #1
Alistair_Heaton
- Nov 4, 2018
- 9,819
That's a lot of capacity that's been lost. Must admit being Aberdonian we always associate Texas with hot and humid... Not snow storms.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Alistair_Heaton (Mechanical) (OP) 16 Feb 21 19:03 said:Any news on the nukes? I seems to remember Texas has 4 two are maritime climate and the other two are central. They are quiet old as well so I doubt they can be run up quickly or for that matter at max
STP spokesperson said:On Monday, Feb. 15, 2021, at 0537, an automatic reactor trip occurred at South Texas Project in Unit 1. The trip resulted from a loss of feedwater attributed to a cold weather-related failure of a pressure sensing lines to the feedwater pumps, causing a false signal, which in turn, caused the feedwater pump to trip. This event occurred in the secondary side of the plant (non-nuclear part of the unit). The reactor trip was a result of the feedwater pump trips. The primary side of the plant (nuclear side) is safe and secured.
