I am reviewing testing certs from a potential new vendor for metallurgical testing, and have identified a potential issue. The material is 4130, approximately 21 HRC. I have two questions on which I would very much appreciate any assistance y'all would be willing to give:
1) The yield strength is somewhat higher (10%+) than it ought to be based on our previous tests at other labs from this same bar, though the ultimate tensile strength, elongation, and other properties are right in line. How much variability is normally to be expected in a tensile test, and is it unusual for a single property to vary so while the others remain constant?
2) The Load-Time curve was provided, and appears to have a discontinuity prior to the yield point (see attached photo). I've not seen this before, and I'm concerned that it might indicate a malfunction of the testing machine, and might have contributed to the issue from question 1. Is my intuition correct, or is this a non-issue?
Thank you!
Thank you!
