Temperature measurement differences of the skin
jahahn
Bioengineer
Jun 5, 2003
I am tasked with finding a low cost wearable portable method for collecting data on human skin temperature over time. It must be able to record changes to within
+/-.3 degrees. Any suggestions on where I might find this technology would be greatly appreciated.
jerry hahn
jhahnemail@yahoo.com
An IR thermometer?
Did you mean +/- 3°C or +/- 0.3 °C?
What does low cost mean?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
They use RDTs for this.
How many points do you need to measure?
You can buy commercial 'select' sensors with good accuracy.
There are very small data loggers (Hobo) that can record data.
Rust never sleeps
Neither should your protection
Thank you for the information on measuring skin temperature. I will restate the temperature requirement since some people questioned my requirement: +/- .3 degrees C, maximum deviation. This is for human skin temperature. Low cost is something we could purchase for a clinical trial which means the sensors must be well under $200.00/person plus the cost of the device for collecting the data.
Jerry Hahn
