In case there are any practical impediments against the fluid jet physical intimate mixing; and the only option considerable is side entry type mixers then,
referring to suppliers/vendors or manufacturers may result in multiple side entry mixer installations at various circumferential shell locations to obtain the required mixing(Although rate/extent of mixing remains very low, gradual; even with religiously changing each side entry mixer angle)
Best Regards
Qalander(Chem)
