Howdy,
So I've tried problems like this before in FEA and have decided to change the design so I didnt have to deal with it. Well in this case I cant change it... I have to figure out the answer. I only have solidworks simulation to play with. I've tried every trick I can think of to relive the point loads but still I cannot get it to tell me that it wont fail at the point in the red circle at a bit over 110 lbs.
So the yellow block is C36000 and the grey pin block is steel 1018. The t slot is blind, keeping the pin block from sliding out. I know from pulling on these things they tear out starting right were solidworks says (in the red circle on the brass) but its a lot more than 110 lbs.
so the t slot flange dimensions are .5"x.125"x.375" and it rides in the t slot... 2 inches. The load is hug by a pin thru the hole. I've all but given up on simulations and hope that some FEA wizards who do hand calcs, know how to hand calc this one.
Thanks!
Thanks!
