Hi ,
We are designing the system network of a new factory. The estimated load is around 10 MW and a nearby IPP will be supplying us power @ 11 k V . The IPP is requesting us to install a 11 / 6.6 k V ( or 1 / 1 isolating transformer ) transformer on our side with the ultimate idea to isolate their network from ours which is understable from the stability point of view.
However, as we have got a very tight budget , we are proposing the IPP to feed directly our 11 k V cell and we will be limiting the ICC through suitable reactor on their 11 k V system. It is understood that the system stability on both our sides and the IPP is questionable as we will be having a common earth .
The second solution will result in considerable saving as we have already in the group transformers , MV panels etc.
I trust that through grading and co-ordination, the second option is as valuable as the first one.
Suggestions ?
Bob
NB Is it possible to insert attachment file to a post ?
Suggestions ?
Bob
