WE HAVE A STEEL ROOF WITHOUT INSULATION, WE NEED TO DECREASE THE HEAT LOAD TO THE ROOM, WE CAN NOT INSTALL INSULATION BELOW ROOF, WE THINK THAT THE HEAT TRANSFER WILL DECREASE WITH THE USE OF ALUMINUM FOIL ABOVE STEEL ROOF. WE VERIFY THE TABLE 3.3 "SURFACE RESISTANCE OF AIR" WE HAVE A STEEL ROOF WITH EMITTANCE OF 0.25 AND R=2.7 (HORIZONTAL SURFACE WITH DOWNFLOW HEAT FLOW). WHEN WE USE ALUMINUM FOIL THE EMITANCE IS 0.05 AND THE RESISTANCE IS 4.55. THE USE OF THIS ALUMINUM FOIL HELP TO DECREASE THE HEAT FLOW 30%. IT IS CORRECT?
