Pardon my possibly silly question but the following is a subject where I have little experience.
Due to other process limitations I have been forced to choose brazing/soldering to join thermocouple measuring points to stainless steel fittings (the thermocouples need to be gorunded).
A high-silver solder used together with a flux intended for stainless steel seems to be a workable solution, but unfortunately the part geometry makes it impossible to ckean all the flux from the joint - I am expecting this to create reliability issues due to corrosion.
I have been trying to solder with electric induction heating and a jet of inert gas onto the hot area but I have not been successful. The solder (a high-silver material for good workability) is balling up and does not wet any of the parts. Also there is visible discoloration of the parts even under the gas jet. The same problem is apparent with 95%nitrogen/5%hydrogen mix, argon and 97% argon/3% hydrogen mix as shielding gases.
What could be the cause of the problem? impurities in the gases? Incorrect purging of gas lines? Incorrect cleaning? Gas picking up contaminants? Impurities in the metal leaking and damaging the surface?
Any guidelines towards the correct direction would be useful! Anyone here has experience with flux-less brazing?
n85
n85
