Surface force/ pressure in custom direction
loki3000
652
is it possible?
i'm trying to load a model in only one direction (strictly), but there is no option of specifying a vector for the pressure (it's just normal to surface). a force isn't good either (no surface contact).
is there anything else? would it be possible to set gravity for each part (there are two and a cohesive element in between) separately?
can someone please explain what am i doing wrong with boundary conditions (view deformed shape). in some other scenarios (like a contra-force) i don't get convergence.
i am trying to fix the below (smaller) part so that i get accurate data on cohesive stress.
 http://files.engineering.com/getfile.aspx?folder=22c165a3-85b6-4da4-933a-0848e74b926b&file=new6.odb
You should be able to apply a traction force as well as a pressure normal to the face, and hence get your vector.
corus
