Sunken Slab Detailing 3
strawhats2000
Industrial
MU
I am looking for any advice re. detailing of sunken slab i.e here a terrace that is 100mm. lower than the remaining slab at First Floor Level.
Any documentations or examples of Two way or One Way Solid RC Slab Detailing with sunken slab, holes or pitch roof design in CAD or PDF format.
KFT032t
Thanks.
May I ask who funds this research?
This is a personal research for use in issuing plans to my clients (regular residential home plans).
Thanks.
Why a reinforced slab? Most "sunken" slabs are on grade. Do you have adverse soil conditions? A bit more info would be helpful.
Also...don't post your email address. It attracts spammers.
I am asking for first floor or any other suspended floors that are supported on RC Beams and not Slab-on-Grade or oversite type of slab. Thanks for the email note.
You'll see details similar to those shown below for steps in the field of a suspended slab. Obviously, if the step occurs right next to a beam, the situation will differ accordingly.
Thanks KootK,
Here is a reworking of your detail with a 100 mm. drop next to a beam. Is this ok? Please feel free to correct. In my case, the slabs are simply supported as beam and slab are not cast in one operation but separately.
Also would you please give me some books or code references where I can get those kinds of information as I am also looking for details re. pitch roof.
qWj3G9m
Thanks and Regards,
Nicolas MARIE
Do you need slab continuity across the step? If so I'm skeptical about your detail. If not than the drop is easy
As jayrod12 wrote, if you need continuity (tension in upper zone) i would prefer this detail of the upper reinforcement. (Tip: I find a slab of 125 mm ridiculously thin)
Hi Tommy385,
I have updated the detail as follows:
getfile.aspx
Also there was an error on the length of the top bars which should be effective span/3.
Thanks for your input.
Where can I find such structural details?
