I found this code somewhere online. I forget who the author was and apologize but it works very well.
I have a column with several measurements in Feet"-Inch" format. The corresponding cells in the column next to it convert the feet and inches to decimals. At the bottom I have a cell that sums the decimals. I have another cell that converts the total back to feet and inches. What I need to do is have a cell that..
1: converts all lengths to decimals at once
2: sums them
3: converts the total back to feet and inches
Basically I'd like to eliminate the need for the extra column.
Any thoughts?
Thanks,
Doug
Public Function feet(LenString As String)
Dim FootSign As Integer
Dim InchSign As Integer
Dim SpaceSign As Integer
Dim FracSign As Integer
Dim InchString As String
Dim Word2 As String
' Copyright 1999, 2005 MrExcel.com
LenString = Application.WorksheetFunction.Trim(LenString)
'The find function returns an error when the target is not found
'Resume Next will prevent VBA from halting execution.
On Error Resume Next
FootSign = Application.WorksheetFunction.Find("'", LenString)
If IsEmpty(FootSign) Or FootSign = 0 Then
' There are no feet in this expression
feet = 0
FootSign = 0
Else
feet = Val(Left(LenString, FootSign - 1))
End If
' Handle the case where the foot sign is the last character
If Len(LenString) = FootSign Then Exit Function
' Isolate the inch portion of the string
InchString = Application.WorksheetFunction.Trim(Mid(LenString, FootSign + 2))
' Strip off the inch sign, if there is one
InchSign = Application.WorksheetFunction.Find("""", InchString)
If Not IsEmpty(InchSign) Or InchSign = 0 Then
InchString = Application.WorksheetFunction.Trim(Left(InchString, InchSign - 1))
End If
' Do we have two words left, or one?
SpaceSign = Application.WorksheetFunction.Find(" ", InchString)
If IsEmpty(SpaceSign) Or SpaceSign = 0 Then
' There is only one word here. Is it inches or a fraction?
FracSign = Application.WorksheetFunction.Find("/", InchString)
If IsEmpty(FracSign) Or FracSign = 0 Then
'This word is inches
feet = feet + Val(InchString) / 12
Else
' This word is fractional inches
feet = feet + (Val(Left(InchString, FracSign - 1)) / Val(Mid(InchString, FracSign + 1))) / 12
End If
Else
' There are two words here. First word is inches
feet = feet + Val(Left(InchString, SpaceSign - 1)) / 12
' Second word is fractional inches
Word2 = Mid(InchString, SpaceSign + 1)
FracSign = Application.WorksheetFunction.Find("/", Word2)
' Return an error
feet = "VALUE!"
Else
If FracSign = 0 Then
feet = "VALUE!"
Else
feet = feet + (Val(Left(Word2, FracSign - 1)) / Val(Mid(Word2, FracSign + 1))) / 12
End If
End If
End If
End Function
Public Function LenText(FeetIn As Double)
' This function will change a decimal number of feet to the text string
' representation of feet, inches, and fractional inches.
' It will round the fractional inches to the nearest 1/x where x is the denominator.
' Copyright 1999 MrExcel.com
Denominator = 32 ' must be 2, 4, 8, 16, 32, 64, 128, etc.
NbrFeet = Fix(FeetIn)
InchIn = (FeetIn - NbrFeet) * 12
NbrInches = Fix(InchIn)
FracIn = (InchIn - NbrInches) * Denominator
Numerator = Application.WorksheetFunction.Round(FracIn, 0)
If Numerator = 0 Then
FracText = ""
ElseIf InchIn >= (11 + (31.4999999 / 32)) Then
NbrFeet = NbrFeet + 1
NbrInches = 0
FracText = ""
ElseIf Numerator = Denominator Then
NbrInches = NbrInches + 1
FracText = ""
Else
Do
' If the numerator is even, divide both numerator and divisor by 2
If Numerator = Application.WorksheetFunction.Even(Numerator) Then
Numerator = Numerator / 2
Denominator = Denominator / 2
Else
FracText = " " & Numerator & "/" & Denominator
Exit Do
End If
Loop
End If
LenText = NbrFeet & "'-" & NbrInches & FracText & """"
End Function
2: sums them
Any thoughts?
Thanks,
Doug
Dim Word2 As String
feet = 0
FootSign = 0
Else
End If
End If
Else
End If
Else
' Return an error
feet = "VALUE!"
Else
feet = "VALUE!"
Else
End If
End If
End If
End Function
FracText = ""
NbrInches = 0
FracText = ""
FracText = ""
Else
Do
Else
Exit Do
End If
Loop
End If
End Function
