Could you advise me how the building is idealized for modal analysis?
In basic concepts and per the requirement of codes, storeys in buildings are assumed as, whole storey mass is being lumped at the storey level. The whole building should have a 2 translation and a 1 twisting rotation defined as DOF per storey basis, and others DoFS should be eliminated via static, dynamic etc.. condensation.
Based on that, columns and beams are assumed as frame FEM (6 DoFs per node) elements, unwanted DoFs (UDofs) are eliminated with condensation, from now on is just my prediction, shear walls are assumed as plane (triangular, quad) elements(2 DOF per node) again the UDoFs are eliminated, so how the slabs and shear-walls are actually being assumed in that process?
