Flabel's book has the most beautiful illustrations of detail design, albeit presented for analysis purposes. The examples used look like real structures. Niu's books have a fair amount of real detail design illustrations in them, from the many companies at which he has worked. Cutler's book has quite a lot of photographs of things like wing ribs and other big fittings in some detail. I'm not sure which one, but I'm pretty sure at least one of these references has a nice illustration of the different sort of shear clipping used to join fuselage longerons to frames at the frame cutouts that the longerons pass through. This illustration contrasted different approaches used on different aircraft.
Designing a good fitting or beam-like part in the real world is something of an art, and I'm not aware of any references which really address that level of detail. You have to take the many and contrasting requirements for strength, fatigue, damage tolerance, inspectability, repairability, environmental fitness (corrosion, SCC, appearance, surface prep), environmental suitability (no cad plate or CAA anymore), different costs, life, etc., and combine your addressing of them all in such a way as to produce a reasonably optimal part. This includes design of geometry, material selection, fastener usage, recurrng vs. fixed costs combined with the overall project policies, and so on. Producing a comprehensive list of the competing requirements for detail desgn is almost pointless, as they vary so much from structure to structure and project to project. The same goes for the different strategies and considerations when deciding how to meet the requirements and optimise the things that don't have simple targets (there may often be a weight target, but there's usually an incentive to save weight and cost always needs to be minimised; there are also competing aspects of some of these things, such as manufacturing cost versus life cycle or "true" cost).
