Hi There,
I have recently designed a part for our machine out of 101.6x101.6x4mm structural square tubing with 4mm thick end caps welded onto each end of the structural member. The intention was to use this square tubing as our pneumatic manifold rather than manufacturing and bolting on a separate manifold.
After giving it some thought, I have become nervous to pursue this design concept as I am not certain that the structural tube has enough integrity to be used as a pneumatic manifold.
Is it possible for us to use the tube mentioned above in the manner I have described?
My manager has suggested that I carry out some calculations to verify if the tube will be up to the task but I haven't got a clue where to even start with such calculations.
Thank you.
Thank you.
